Clutch not engaging
cwyett
Clutch not engaging
Post by cwyett » Thu Sep 06, 2012 1:38 pm
I have a 1966 CB77 Supwerhawk that i recently got running, it idles just fine but come time to ride it, the clutch wont engage and allow me to get into first gear. i did some adjustments with the cable itself on each end but it still wont engage.
is it possible there is something else that can be adjusted in the crank case?
im at a bit of a loss so any info on clutch adjustment or attachment would be much appreciated.
thanks!
Re: Clutch not engaging
Post by LOUD MOUSE » Thu Sep 06, 2012 4:25 pm
More than possible the plates are stuck. ..............lm
cwyett wrote:I have a 1966 CB77 Supwerhawk that i recently got running, it idles just fine but come time to ride it, the clutch wont engage and allow me to get into first gear. i did some adjustments with the cable itself on each end but it still wont engage.
thanks!
Hahnda
Post by Hahnda » Thu Sep 06, 2012 4:30 pm
See if you can get someone to help you bumpstart it in 2nd gear. Ride it around like that working the clutch and it might free up.
cron
