I had a sticking clutch so I took it apart to get the rust off of the plates. Now, putting it back together, I notice that the plates have a rounded slot cut every four teeth and pointing toward the outer rim. Are these supposed to line up with each other, or not line up with each other, or does it make any difference at all?
Thanks
                    Clutch plates--Do the channels have to line up?
				Cheburashka
Re: Clutch plates--Do the channels have to line up?
Just install them.
There is no certain location for the slots. ........lm
Cheburashka wrote:I had a sticking clutch so I took it apart to get the rust off of the plates. Now, putting it back together, I notice that the plates have a rounded slot cut every four teeth and pointing toward the outer rim. Are these supposed to line up with each other, or not line up with each other, or does it make any difference at all?
Thanks
