Electrical Starter Rebuild?
MRiesAP
Post by MRiesAP » Tue Sep 25, 2012 8:39 am
Good morning,
Does any one know if there are rebuild kits for starters or someone who rebuilds them? Mine is a locked up brick right now.
48lesco
Post by 48lesco » Tue Sep 25, 2012 12:23 pm
Don't know of any rebuild kits. I've rebuilt a couple over the years because I like to rebuild stuff, but if I was smarter, I would just buy one of the 25 of them for sale on ebay for $50.
http://www.ebay.com/itm/1960-CA77-DREAM ... 9e&vxp=mtr
Why not take yours apart and see why its locked up. Just a few screws to split the gearbox. Probably a broken gear that someone could just send you and you would be back in business. Once you take the gears out, see if the motor itself spins with 12V. If not, then ebay...
-48
jleewebb
Post by jleewebb » Tue Oct 02, 2012 12:35 pm
48lesco wrote: Why not take yours apart and see why its locked up. Just a few screws to split the gearbox. Probably a broken gear that someone could just send you and you would be back in business. Once you take the gears out, see if the motor itself spins with 12V. If not, then ebay...
-48
care to elaborate? I'm having a hung starter problem as detailed on another thread today.
do I need to pull the starter to check it, or just cover(s) on rotor and/or clutch side to see what's going on? Problem seems to be 0 resistance from starter terminal to ground, seems to me there should be a few ohms resistance through the starter motor. So I guess I need to be looking at wiring on the right (rotor) side.
Thanks, Lee
'62 CB77. "It's a rider."
48lesco
Post by 48lesco » Tue Oct 02, 2012 10:26 pm
Lee - see my response in electrical. You can remove the starter and split the gearbox pretty easily. Let's take it from there...
