How to separate the grips from the handlebar?
terecha
Post by terecha » Mon Oct 01, 2012 2:33 am
Like in subject how to without any grip failure? I have to copy grips from the other bike (not SH) and I don't know how to remove them carefully.
brewsky
Post by brewsky » Mon Oct 01, 2012 9:23 am
Spray WD40 between the grip and bar, twist back and forth, and pull.
Will come right off no problem.
Post by G-Man » Sun Oct 07, 2012 2:05 pm
Hot water will help, too...
mike in idaho
Post by mike in idaho » Sun Oct 07, 2012 7:10 pm
Compressed air works well to get grips loose. Hold the blow nozzle of an air hose against the hole in the end and blast away while you twist the grip. The air pressure swells the diameter enough allow the grip to slide right off.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
houseowax
Post by houseowax » Mon Nov 12, 2012 1:00 pm
I used a heat gun- held at a distance. Sprayed WD40 into the grip as it softened up and then heated up again. Slid right off without a fight.
'63 CA77 - Giving me all kinds of headaches.
'64 CA77 - Patiently waiting it's turn
'65 CB77 - A 'great winter project'
