ca77 oil
bluejean
ca77 oil
Post by bluejean » Thu Oct 18, 2012 4:36 am
This might be a dumb question, but I can't seem to find out what type of oil I should use for my 1964 ca77.
rustywrench
oil
Post by rustywrench » Thu Oct 18, 2012 10:47 am
Bluejean,
The last time some one asked this it ended up in a 50 some page train wreck of a thread.
Look at the casing near the engine number and you will see that the manufacture calls for 30W non detergent oil.
You can also use a blended more modern oil formulated for the wet clutch with good success.
Some here would argue that the detergents of modern oils "MAY" suspend the particles not allowing the oil spinner to work properly. To offset that concern; why not change oil more frequently?
IMHO, either oil will work well as they are designed to do. The bottom line is that you get to decide for yourself which is best for you. Welcome to the madhouse,,,,,,, Rusty
conbs
Oil
Post by conbs » Thu Oct 18, 2012 11:15 am
bluejean,
Please add you location to your profile. There may be a Forum member in your area who can help you with the myriad of questions you will surely have.
Also, learn to use the search function on this site (in the bar above this screen). Use different words and/or combinations of words. Also click the "posts" icon lower left for better results. There is not much about these bikes that hasn't been discussed. Using the search function will get you to that information in the shortest time and you will learn an amazing amount of additional information along the way.
Best wishes with your bike.
Post by G-Man » Thu Oct 18, 2012 11:17 am
Well put Rusty....
Bluejean - To quote an old friend of mine... "there are no dumb questions, just dumb answers"....
