Raising compression ratio
Greener101
Post by Greener101 » Fri Oct 19, 2012 9:00 am
I will soon start the rebuild of my 1962 CA77E 305.Upon completion I plan to utilize both fuel injection and a high energy ignition.I am considering raising the compression ratio to 9.0-9.5.Can someone steer me to the best path to this end?I would like to do this with just a piston swap.BTW, a PO has been in the engine previously so I plan a complete rebuild as I do not trust his competency.Greener
Greener101
Post by Greener101 » Sat Oct 20, 2012 4:13 pm
Is this change not possible?Does anyone know of a person who I can message directly?I was hoping someone else had accomplished this feat and knew of the best and cheapest route to this end.Thanks for looking.Greener
Ford Guy
Post by Ford Guy » Sat Oct 20, 2012 7:09 pm
Piston swap would be the easiest. May I ask why you would want to raise the compression ratio?
Greener101
Post by Greener101 » Sat Oct 20, 2012 8:37 pm
Ford Guy,Anticipated miles will be nearly all divided four-lane highway.I believe the higher compression will be more efficient, allowing a crisper response for passing(when necessary) .Greener
Post by G-Man » Sun Oct 21, 2012 2:07 am
Greener
The CA combustion chamber is larger than the CB/CL so you cannot use those pistons to get higher CR. You need to find another similar 60mm piston with a higher dome. CB750 pistons are larger bore but have a flat top so they won't work.
British pistons will have a bigger gudgeon pin diameter and be heavier. Might be easier to skim a little off barrel or head but then you need to look out for clearance problems.
If you can find a set of the early 4-ring Dream pistons, they are supposed to give 9.5:1 so you might be lucky. Not sure why the 4-ring (266-010) piston was superseded but weight and friction would have been considerations.
Then again, you could try these......
http://www.ebay.co.uk/itm/NOS-Honda-CB7 ... 43b4b4fa66
Good luck.
Greener101
Post by Greener101 » Sun Oct 21, 2012 4:48 am
Thanks G-man for the information.The compression is a lot higher than I was looking for,but I will look into shaving the dome to reduce the ratio to something more to my liking.This will at-least give me somewhere to start.How early are the 4 ring Dream piston?When you use the term Dream,which Dream do you mean ?I ask this because some refer many bikes as Dreams just like many refer any Honda 305 as a CA77.Greener
Post by G-Man » Sun Oct 21, 2012 6:43 am
Greener
The 4-ring pistons were used on 1960 C72 and C77, I think. May have been used on C71 / C76 too. I have a single NOS C72 one.
