check it
jleewebb
check it
Post by jleewebb » Thu Oct 25, 2012 2:53 pm
be sure and re-check timing after you tighten up the points...mine tends to retard it a bit when tightened up so I set it a little advanced, tighten, recheck, loosen, set it a little more advanced, tighten, recheck, loosen, set it a little less advanced, tighten, recheck...you get the picture.
'62 CB77. "It's a rider."
48lesco
Post by 48lesco » Thu Oct 25, 2012 3:09 pm
jlee - I sometimes cheat and just bend the stationary side of the points a little with needle-nose pliers to get a degree or two of timing change with the engine running (slightly change the gap without loosening the screws). Open them up to advance, close to retard.
-48
jleewebb
oops
Post by jleewebb » Thu Oct 25, 2012 3:24 pm
ok...this was supposed to be a reply to post on CB77 type 1 ignition timing
hit the wrong button...
