CA77 Rear Tail Light Problem
quidger
Post by quidger » Sat Oct 27, 2012 11:12 am
I'm about done re-assembling the 1968 Dream and I have one little snag that I hit. I would like to ask for some advice.
Electrical was 100% fine when I disassembled the bike. Upon reassembly all electrical is working well with the exception of everything related to the tail and brake light.
I had to do a lot of Bondo work on the top and near the brake light mounting holes area of the rear fender. I assume that the tail light uses the fender as a ground so I chipped off the Bondo to expose bare metal at the contact points where the brake light housing mounts to the fender. I sanded off all paint on the housing so that the two bare metals would have good contact area. Still no lighting for any of the rear light functions. I decided to try to circumvent the fender as a ground and directly ground the lamp. So I thought if I ran a ground wire directly from the tail light ground (copper wire ground that goes directly to the bulb) and clamped it to the motor fins that I should get a solid ground and thus, lights. No cigar. Should this maneuver have given me a good ground?
I am certain that the bulb itself is good.
I also checked and cleaned the connection where the wires are soldered to the bulb.
There were a few bare spots on the blue and the white wires that were in evidence when I took the bike apart. I electrical taped all of these area before I reassembled the bike. Wouldn't think that this would be an issue since the tail light functioned well prior to dis-assembly and prior to the electrical tape being applied.
I'm not sure how I might be able to test the connections with a multimeter or even if this is a situation where I should use a multimeter.
So if someone can give me some guidance or ideas on what they think the issue might be, it would be most appreciated.
Thanks
S90 / CB550 / CA 77 Dream 305 / Yamaha RT2 360
conbs
Electrical Problems
Post by conbs » Sat Oct 27, 2012 10:51 pm
Looks like this thread should be in the electrical Forum. It could get long, so maybe better to start it there.
