Ca 77/78 original color
Gadgitman
Post by Gadgitman » Fri Nov 09, 2012 11:37 am
Is there a way to tell what color my bike was originally? Any way by the #'s or just scrape or look hard? Thanks for any help!
jensey
Post by jensey » Fri Nov 09, 2012 1:46 pm
If the bike has original rear shocks, check the inside of the top cover,
Gadgitman
Post by Gadgitman » Fri Nov 09, 2012 1:53 pm
Thanks! I will check.
pknopp
Post by pknopp » Fri Nov 09, 2012 8:34 pm
WHat color is it now? Why might you think it not original? Inside the headlight bucket is another place. Inside the side covers. Chain cover. Taillight.
Gadgitman
Post by Gadgitman » Fri Nov 09, 2012 9:02 pm
It's blue now, well like 3 shades of blue. I was hoping that there was a paint code plate or number.
jensey
Post by jensey » Sat Nov 10, 2012 3:13 am
So, you asked the wrong question ?
You knew it was original blue, but you wanted to know the colour code ?
There's enough info about that on the forum, why didn't you search for the answer in the paint section or using the search function ?
Gadgitman
Post by Gadgitman » Sat Nov 10, 2012 9:34 am
I was thinking it was white when new because the rear fender has a spot about the size of a half dollar where the blue paint fell off and it's white there. One shock had a sticker I didn't like and pulled it off. Under there was black. Inside the headlight is black. Inside the left ( coil ) cover is green. I noticed while putting on the new front tire that the underside is black. The swingarm has a spot that looks red thru a scratch. The tank paint is worn off where the seat rubs it and looks all blue. I am thinking I might have a mutt! I really believe in keeping any classic as close to original configuration as economically possible. But I really like black! My other 3 classic Hondas are black 2 where originally black. The only one I changed to black from yellow is a very radical custom. If no one can tell what color by looking at a number or code on the bike then I will eventually paint it black or maybe even white.
