Having trouble getting ANY spring in throttle handle—it just sticks when I twist it with no pop back at all. I did change the handle bars to strait instead of high rise so there is probably access cable now, it worked ok before that. I adjusted the screws near the handle all the way out to increase tension to no avail. Not sure what's next, or how to shorten the cable. Any thoughts?
thanks much!
adjusting throttle cable advise?
Re: adjusting throttle cable advise?
May be as simple as moving the throttle out 1/8 inch. .......lm??????????
bart3 wrote:Having trouble getting ANY spring in throttle handle—it just sticks when I twist it with no pop back at all. I did change the handle bars to strait instead of high rise so there is probably access cable now, it worked ok before that. I adjusted the screws near the handle all the way out to increase tension to no avail. Not sure what's next, or how to shorten the cable. Any thoughts?
thanks much!
Thanks, I tried to move the handle and cable a bit to the right but it didn't seem to make a difference. May just need a shorter cable now. Appreciate the advice!
If there is a screw at the bottom of the throttle I recommend you back it out to see if it is the problem. .......lm
bart3 wrote:Thanks, I tried to move the handle and cable a bit to the right but it didn't seem to make a difference. May just need a shorter cable now. Appreciate the advice!
sticking throttle
Are you sure the carb slide isn't sticking? I had that on mine, if the two carb nuts are too tight it torques the body and the slide sticks open. When I loosened them a bit, it just snapped back in place.
