Engine Swap Easy?
helmetsplitter
Engine Swap Easy?
Post by helmetsplitter » Sun Nov 25, 2012 12:18 am
I've have a 305 CL77 with a siezed engine.
I have purchased a '66 Super Hawk engine that appears in good shape.
Is this an easy swap? What kind of problems will arise?
Will the right engine cover interchange with the 77 to make it kick start rearward?
Is the SH an alternative stroke engine or same-at-once like a dream? (will it sound like a 77)
BTW, Can anyone cut a new ign. key?
Re: Engine Swap Easy?
Post by LOUD MOUSE » Sun Nov 25, 2012 8:04 am
Head and side case swap with no problem.
What #key do you need?. ....lm
helmetsplitter wrote:I've have a 305 CL77 with a siezed engine.
helmetsplitter
Engine Swap Easy?
Post by helmetsplitter » Sun Nov 25, 2012 9:54 am
Key code N603
Also NA 306 from the Super Hawk
Post by LOUD MOUSE » Sun Nov 25, 2012 10:18 am
I don't have either one. ....lm
helmetsplitter wrote:Key code N603
helmetsplitter
Post by helmetsplitter » Sun Nov 25, 2012 10:34 am
Does the crank send both pistons up at once on the Super Hawk or do they alternate like the 77?
Thanks
Post by LOUD MOUSE » Sun Nov 25, 2012 10:58 am
Depends on the issue of the CB77 engine.
Look at the points and you will have your answer. ....lm
helmetsplitter wrote:Does the crank send both pistons up at once on the Super Hawk or do they alternate like the 77?
Thanks
mike in idaho
Post by mike in idaho » Sun Nov 25, 2012 11:58 am
Thanks
They're basically the same engine, you will need to remove the electric starter, it will bolt right in.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
