Spark advance springs
Husker45
Post by Husker45 » Fri Dec 21, 2012 4:05 pm
I installed a new set of spark advanced springs on cam sprocket. The advance arms have some play before the springs pick up. Is this normal? Thanks for any info.
Re: Spark advance springs
Post by LOUD MOUSE » Fri Dec 21, 2012 4:18 pm
What engine.
If it is a CB/CL and you installed CA they are longer and not correct. ......lm
Husker45 wrote:I installed a new set of spark advanced springs on cam sprocket. The advance arms have some play before the springs pick up. Is this normal? Thanks for any info.
Husker45
Post by Husker45 » Fri Dec 21, 2012 4:27 pm
Good afternoon Loud Mouse. My engine is a cb77 (CB77E-212739). The replacement springs were part number 14329-268-320 from Classic Honda Restoration. The original springs also allowed some arm play and since I didn't know if that was correct decided to replace them.
Post by LOUD MOUSE » Fri Dec 21, 2012 5:26 pm
Any chance you mean in/out or up/down?. .......lm
Husker45 wrote:Good afternoon Loud Mouse. My engine is a cb77 (CB77E-212739). The replacement springs were part number 14329-268-320 from Classic Honda Restoration. The original springs also allowed some arm play and since I didn't know if that was correct decided to replace them.
Husker45
Post by Husker45 » Fri Dec 21, 2012 5:38 pm
I guess I would describe it as in and out. Or a better way to say it would be the spark would advance with no spring resistance for some number of degrees as the arms move out. Does all of that make any sense?
Post by LOUD MOUSE » Fri Dec 21, 2012 6:16 pm
Not god.
Need to have little if any advance.
I suggest none. . ........lm
Husker45 wrote:I guess I would describe it as in and out. Or a better way to say it would be the spark would advance with no spring resistance for some number of degrees as the arms move out. Does all of that make any sense?
Husker45
Post by Husker45 » Sun Dec 23, 2012 10:38 am
Loud Mouse, do you think I have the wrong springs or a problem with the cam sprocket. What would you inspect on the cam sprocket?
