Electric ignition upgradeElectric ignition upgradeHas anyone had experience with the new electric ignition for a 305? Is it worth the money? Is there any real difference? It costs over 3 hundreds. Sincerely CFL
Re: Electric ignition upgradeI have installed the PROBE ignitions on several bikes and IMO they are worth the $$$ as they work and don't need to be adjusted later. ........lm
I have an ignition from Sachse, check the link here : http://www.elektronik-sachse.de/index_en.htm . The big advantage above most other ignitions is that the timing is determent on the crank instead of the cam. It has also programmed ignition curves (9 different ones), well take a look for yourself, Jensen assembly of Japanese motorcycles requires great peace of mind (Pirsig)
