Piston
mark1505
Piston
Post by mark1505 » Sun Feb 17, 2013 9:12 pm
Is there any other pistons for my 1967 CL77 other than 13102-275-020.
$80 bucks for one piston and $75 for rings is crazy.
My engine was stuck and I broke the skirt on one piston getting it lose.
I will need to bore the sleeves anyway to clean them up.
I have another complete engine from a CB305. Can I use the pistons and sleeves
in the CL?
I want to build the engine correct but $300 for 2 little pistons is HIGH.
Thanks
Mark
Post by G-Man » Mon Feb 18, 2013 2:07 pm
Mark
If your spare is a CB77 (305) you should be fine to swap barrel and pistons.
Keep looking on eBay. Bargains do turn up especially if you buy individual pistons and not pairs.
Rickytic
Post by Rickytic » Tue Feb 19, 2013 1:13 pm
Mark,
Just my 2 Cents. Seems to me that you might want to get the sleeves cleaned up first to find out what size pistons you need. There is a set of pistons on Ebay currently. Go to Ebay motors, Honda 305 scrambler, and they should be there. Purchasing pistons before you know what you need might be a waste of your resources. Again, just my thought process. Good luck.
Rickytic
