Low gear part numbers - 23420-253-000 vs 23420-253-020
Bob750
Post by Bob750 » Sat Mar 02, 2013 3:20 am
Can anyone tell me the difference between the two parts above? (Gear, Low 35T)
The dogs on mine are rounded, and while looking up the part I found Honda used 2 part numbers. My '64 CA has engine CA77E-1056xx (frame CA78-1056xx) and so would use the earlier -000 part (manual says it's used through CA77E-1033686 with the -020 part used after that), but I want to know if there's a way to tell them apart from photos I see on the web. Also, are they interchangeable? I've seen someone selling a -000 part that "came off a 1969 CA77" so it's either a mistake or someone had swapped the original tranny for an older model. Right?
Bob
Re: Low gear part numbers - 23420-253-000 vs 23420-253-020
Post by LOUD MOUSE » Sat Mar 02, 2013 10:44 am
As near as I know they are the same as for installation and working with the other gears. ..........lm
Bob750 wrote:Can anyone tell me the difference between the two parts above? (Gear, Low 35T)
Bob
48lesco
Post by 48lesco » Sat Mar 02, 2013 6:16 pm
The difference might only be in the forging/machining on the side with the dogs. I have a good used one I just relisted on ebay for $10 if you're interested.
Bob750
Post by Bob750 » Sun Mar 03, 2013 1:09 am
Thank you, Ed!
LOUD MOUSE wrote:As near as I know they are the same as for installation and working with the other gears. ..........lm
Bob
Post by LOUD MOUSE » Sun Mar 03, 2013 8:43 am
You are welcome. .............lm
Bob750 wrote:Thank you, Ed!
Bob
Bob750
Post by Bob750 » Thu Mar 07, 2013 11:43 am
For some reason I never saw your reply. Thank you for the info/offer. I had already begun bidding on an NOS -020 part on eBay. I won and it should be here tomorrow or Sat. If I need a different one I'll contact you!
48lesco wrote:The difference might only be in the forging/machining on the side with the dogs. I have a good used one I just relisted on ebay for $10 if you're interested.
Had: '75 CB550 K, '79 CT90
