Oil slinger and kicker gear - washer dimensions?
plankspanker
Post by plankspanker » Tue Mar 05, 2013 6:56 am
Hi folks - new member posting for first time here. Wondering if anyone has accurate dimensions for the often-mentioned misplaced oil slinger washer? (Thickness most critical, but ID and OD would help too).
Also: Hoping same info can be provided for thrust washer(s) that go on either side of the right side case in conjunction with the kicker gear.
If there is a source for any of these parts any info would be appreciated. Thanks!
Post by G-Man » Wed Mar 06, 2013 10:47 am
Oil Slinger washer
22.7mm OD
14.35 ID
1mm thick
Bob750
Post by Bob750 » Thu Mar 07, 2013 1:09 pm
Washer, Oil Filter Rotor 15493-259-000 can be found at Tim McDowell's store: ClassicHondaRestoration.com
I've spent many dollars at Tim's store. He's a nice guy and responds well to any issues you may have.
I've seen the Kick Starter Spring Washer 90423-250-000 listed at Ohio Cycle.
Bob
Had: '75 CB550 K, '79 CT90
