Since 1994 I've been riding my 1974 Honda CB750 K4 which I purchased from the original owner at 16K miles. Today it has over 41K. I've done a little work on it but nothing too deep, and I've kept it 96% stock (just paint, mirrors and a 4-into-1). In September 2009, I got married, and my wife eventually became tired of riding on the back and wanted to ride her own machine. So she took the MSF Rider Course and got her M1 license. After shopping for bikes with a low seat height (she's 5-3), in the first week of August 2012, we bought a 1965 Dream 305. She was drawn to the very unique lines and character, and it grew on me too--though I feel I'm a bit more of a Superhawk guy, but hey, it's her bike, not mine. I like it more and more, though.
Our bikes the last time they were out together before the tear-down:
Now, you may have noticed that the model year in the above paragraph is different than the one in the title. That is because when we went to look a the bike in Ventura, CA, (we're in Long Beach, CA 85 miles south), the title the PO presented said 1965, and that's what we were there to see--a '65 Dream. The frame and engine numbers on that title matched those on the bike and his name matched his photo ID and the title. After a test ride and verification that everything worked, we bought it, after all, we had traveled all this way with a borrowed M/C trailer...
See, we didn't want a “project.” We wanted a rider, you know, so my wife and I could ride together on our own bikes. We had found honda305.com while looking for info on these cool vintage bikes. But it wasn't until after we had the bike in our garage that we found out about Bill Silver. We immediately discovered, based on his material and the actual serial numbers on the bike, that this was not a '65, which would have made parts a little easier to ID and come by. We had not only a '64, it was an EARLY 64. After the “holy sh#t” moment wore off, we knew this would need to be corrected during registration.
We registered the bike with DMV as-is, so we could legally ride it. So DMV needed CHP to do a VIN check. We provided the pertinent pages from Bill Silver's book to the VIN officer. And after he did his research he agreed with us; this was indeed an early 1964. DMV then gave us a new blue on white plate which looked even funnier on the bike than the yellow on blue one it came with. (Apparently the '65 error must have happened in the 70s for it to have that blue plate.) [EDIT: I've since learned that there may not have been an error in titling as in Calif., many vehicles are titled when they are first sold. But the bike has fallen out of the DMV's system at least twice (once now, once prior to 1982, when it got the Blue plate.) /EDIT] We bought a gorgeous, restored gold on black 1964 YOM plate off eBay, paid the extra DMV fee to have the black plate transferred to our new, edited title. Things were looking up... and much more “period!”
While the registration stuff was happening, we rode it around and had a couple issues with tank fluff alternately clogging the float valve, starving the engine of fuel, and then blocking the float valve from closing, causing fuel to leak out and make the bike look like it was “lifting a leg” right there in public. During the carburetor servicing I noticed that the float was dripping more fuel that it should have been, and then I saw the tiny holes. A new float in the clean carb with new packing, and it ran much better than it had days before. An elusive loose condenser wire connection prevented it from starting for a frustrating two weeks (barrel connection looked complete, but wasn't!). The stiff clutch and hard to find neutral was alleviated somewhat by a new clutch cable and a fresh set of Barnett plates and disks with new Honda springs. And things were pretty good. For a time.
We've put about 230 miles on it and two oil changes to clean things out--one about 10 miles after we bought it and another 100 miles later. It seems to be getting about 100 MPG. Strange things started to happen, however. Downshifting into 1st caused the kick start lever to graze my calf and ankle and slam into the top of the right muffler, denting it. Luckily I hadn't put on the new mufflers from Classic Honda Restoration yet! It was quite a startling moment. But then it happened again. I removed the kick start lever. Intermittently the shaft would still move on it's own. We adapted by not downshifting to 1st until just about to a stop. Finding neutral was also sometimes difficult. Then it would occasionally jump out of and back into gear when accelerating from a stop in 1st. It would also occasionally seem to find a false neutral when shifting from 3rd to 4th. After consulting with MrHonda and the forums for advice, I decided it was time to tear into the engine.
>>> Skip to here. <<<
Now that the engine is apart, I am seeking more advice and opinion from the wiser eyes on this board to let me know if some of these engine components are serviceable or should be replaced. I'll present photos that best show areas of concern in hopes some of you can confirm or placate my suspicions.
EDIT 4/12/13: I have since received replacement parts (some NOS, some good used, from several sources) for the following units, so I'm removing some of the photos... /EDIT
After cleaning the parts, the most obvious problems seem to be with the following parts. I need to know which ones I need to source before I reassemble. Please note that in addition to the images I've posted here, it's a public photo album; so feel free to browse the pics and provide any feedback you think is warranted. I'll greatly appreciate it!!
Low Gear 35T 23420-253-000 – Obviously rounded dogs and rough-worn surfaces. I've already won an auction for an NOS replacement (23420-253-020). LM thinks that there should be no issue using the newer part number. If there are issues, I'll get a -000 part. My concern with this part is that there is wear that is not smooth, like galling on both sides of the gear and on the Kick Start Spindle where they meet.
EDIT: The NOS replacement part I received from an eBay seller was actually a mis-identified 34T from some other transmission, so I returned it and got a good used -000 part from a member here. /EDIT
Kick Start Spindle 28250-259-000 – Has what seems to me to be non-standard wear and gouging. Don't want to have to but will buy a new one if needed.
EDIT: Got a NOS one from eBay. /EDIT
Kick Spindle Pawl 28255-250-020 – Is it worn enough to warrant replacement? I think so, but I've seen pics of worse ones.
EDIT: Replaced with NOS one from eBay. /EDIT
Kick Spindle Metal Bushing 28258-359-010 – What about those circular marks?
EDIT: Replaced with NOS from member. /EDIT
Drive Sprocket – It may be hard to see in the (deleted) photos, but there is some wear on one side of the teeth. Should I flip the sprocket over or source a replacement?
EDIT: I'm going to use this until later when I will replace both sprockets and the chain all at the same time, because the rear sprocket is not in that great of shape. /EDIT
I also have a repro Bushing C from Classic Honda Restoration that will replace the stock one. The new one has a thicker ridge. (See photo.)
Shift Forks - What do you think?
EDIT: All good. Deleted Photo. /EDIT
Main Shaft - Pitting. Keep or replace?
EDIT: Replaced with good used from member /EDIT
There's some case damage, but I think it's minor. Link to the pic and use the left and right arrows to see the other 8 images adjacent to this in the album. Any of these cause for concern? I know that these happened during or before my PO's ownership and likely before the last time the cases were split. This pic shows two bits of damage: 1 in the crank bearing boss, and 1 in the "wall" between the crank area and the transmission area.
EDIT: It has been determined that none of these instances of damage are problematic. /EDIT
https://plus.google.com/photos/10969791 ... 5159492546
Other Questions:
Can the crankshaft sections be easily separated for cleaning & inspection? Does it require special tools/techniques? Just tugging on them hasn't worked. Though the right hand end's roller bearing came out fine of course.
EDIT: No. Leave it together; just clean out the crud catchers in the counterweights. /EDIT
The valve train is still in the head. Pistons, domes and valves needs decarbonizing. How about a self-rebuild? I'm a recently certified A&P. But I lack many specific tools and machinery in my garage that I would want to use in order to do the top-end rework.
EDIT: Sent it out to LM... /EDIT
...snip...
Thanks for your time, interest and advice!
Bob
