puzzled by clutch assembly CB77
Ken184
Post by Ken184 » Sun Mar 24, 2013 5:36 pm
this is my first time so must be something dumb. I think all the parts are there and assembled in the right order, but i can't get the pressure plate to move. without the pressure plate in place, i can see that if i squeeze the clutch the clutch lifter piece moves out about 1/8 or so,but when put the pressure plate in place with no springs it doesn't move. if i then screw the right-side adjustment to push the clutch lifter out a little, thinking maybe it's just that it isn't contacting the inside of the pressure plate, then i can't squeeze the clutch lever at all. it locks up.
Re: puzzled by clutch assembly CB77
Post by LOUD MOUSE » Sun Mar 24, 2013 6:36 pm
Did you put the Clutch Lifter Joint in the shaft before you put the pressure plate in the basket?. ......lm
Ken184 wrote:this is my first time so must be something dumb. I think all the parts are there and assembled in the right order, but i can't get the pressure plate to move. without the pressure plate in place, i can see that if i squeeze the clutch the clutch lifter piece moves out about 1/8 or so,but when put the pressure plate in place with no springs it doesn't move. if i then screw the right-side adjustment to push the clutch lifter out a little, thinking maybe it's just that it isn't contacting the inside of the pressure plate, then i can't squeeze the clutch lever at all. it locks up.
Ken184
clutch problem reply
Post by Ken184 » Sun Mar 24, 2013 8:05 pm
yes. clutch lifter rod from adjuster barrel on right thru tranny shaft. clutch lifter piece inserted in clutch center on left side. then pressure plate. as i said, when the adjuster is turned counter-clockwise to the max, squeezing the lever moves the rod but not the pressure plate. if i turn the adjuster clockwise to make contact, then i can't squeeze the clutch at all. Nothing moves. Is there some initial setting of the adjuster i am missing?
cknight
Post by cknight » Mon Mar 25, 2013 7:43 am
Ball bearing inserted into clutch lifter? Regards, Chase
Ken184
ball bearing in clutch lifter
Post by Ken184 » Mon Mar 25, 2013 6:32 pm
i see now that the lifter bottoms out against the end of the main shaft. the cup in the lifter is too deep. am i missing a ball bearing that fits in there and contacts the end of the lifter shaft? if so, do you know the dimension so i can try to find one?
cknight
Post by cknight » Tue Mar 26, 2013 8:16 am
That would be a 5/16 ball bearing (also known as a #10). Regards, Chase
Ken184
ball bearing
Post by Ken184 » Tue Mar 26, 2013 8:39 am
thank you, Chase. you have been very helpful.
