66, 305 Cl77. Went through the search area without success. Getting ready to button up the left side case (Clutch side)..........The question is, do I use gasket sealer or not, and if so, any suggestion on what type and brand?
Thanks
Rickytic
Left side cover
I like Gasgacinch. A light coating on each side of the gasket. It tacks up and holds it in place while you assemble. No leaks, and when you take it apart it peels off of the case and cover easily without scraping.
Had: '75 CB550 K, '79 CT90
Re: Left side cover
The answer above uses something but HONDA didn't and I don't ether.
I've never had a leak problem with any gasket used with these engines. .....lm
Rickytic wrote:66, 305 Cl77. Went through the search area without success. Getting ready to button up the left side case (Clutch side)..........The question is, do I use gasket sealer or not, and if so, any suggestion on what type and brand?
Thanks
Rickytic
