does this indecate a short?
billyfly1
Post by billyfly1 » Wed Apr 17, 2013 5:42 pm
positive terminal disconnected,,, negative still hooked up....I get a 0.211 volt reading from positive wire {not connected to anything} to ground...does this say a problem? ....thank you ,,,,billy
Post by G-Man » Thu Apr 18, 2013 9:42 am
Yes - probably with your meter......
Hold only the plastic part of the probes and touch the tips together. What reading do you get?
Goodysnap
Post by Goodysnap » Thu Apr 18, 2013 9:56 am
G's right. If you touch the test leads or make the connections with your fingers your body Is conductive. However small the amount.
64' CB77
65' CB160
billyfly1
Post by billyfly1 » Thu Apr 18, 2013 12:50 pm
thank you for reply,,, was only touching plastic,,,when i check for current the other way(positive hooked up negative in series with meter) no amp reading....billy
billyfly1
Post by billyfly1 » Thu Apr 18, 2013 12:51 pm
G-Man wrote:Yes - probably with your meter......
ahh!!!! nevermind!!! thank you, thank you!!!
