separating an engine case with honda bond
rickytile
Post by rickytile » Tue May 21, 2013 9:42 pm
i am having difficulty separating an engine case with honda bond. does anyone have an easy method or tool to assist. I dont want to use a rudimentary hammer and flathead to casue permanent damage. thank you!
jsmith1107
Post by jsmith1107 » Wed May 22, 2013 8:15 am
LM told me this one and it worked for me so here you go. There are two bolts sticking out the top of the engine where the painted engine guard goes correct? Take a 2x4 or a piece of hard lumber and a hammer---put the lumber on the bolts and smack it hard with the hammer a few times. It will maybe take a few good smacks but it will come loose. I did this and it took about 10 good whacks and it finally came loose.
Hope that helps.
1974 Yamaha DT125 Enduro
1974 Harley Davidson AMF X90
1976-7 Yamaha XS 650
2-1966 Honda Scrambler
1973 Suzuki T500 Titan
Hoosier Tom
Post by Hoosier Tom » Wed May 22, 2013 8:17 am
Don't forget about the two top studs with the 8mm nuts. Loosen those and set the nuts flush to protect the stud threads, and after making sure all bottom nuts and bolts are out, whack the protected studs to loosen the cases. Put a small block of wood over the studs/nuts and hit it.
HT
rickytile
Post by rickytile » Wed May 22, 2013 11:19 am
thank you gentlemen. the problem now is that the side cover has honda bond on it too and i cant pry it off. any suggestins on that front?
Jethro
Post by Jethro » Wed May 22, 2013 12:28 pm
Just some patience, a razor blade, maybe a soft blow hammer and some finesse.
