CL77 Late Model Wheel Bearings
Spitfire151
Post by Spitfire151 » Fri Aug 30, 2013 7:49 pm
Anyone know the size of these? I'm trying to order All Balls bearings to replace my front two sets and well it's been a task. All Balls' site doesn't list the 305 but does list the 350 and cross-referencing them on the bikebandit site shows that the 69 350 uses the same part# however All Balls only sells a whole kit which I don't need, while other sites sell just the bearings and of course All Balls doesn't give dimensions.
As always, any input would be greatly appreciated.
conbs
Front Wheel Bearings
Post by conbs » Fri Aug 30, 2013 11:54 pm
6302R according to the parts manual. There are cheap ones on ebay.
If you get sealed bearings you can re-use the old seals in the wheel to keep dust away from the bearing.
Take the seals out of both sides of the new bearings and put more grease in the bearing. Put the seals back in both sides and you shouldn't have to worry about them for a long while. They likely won't ooze any grease either.
If you do this, remember never to put any grease in the zircs again.
Spitfire151
Post by Spitfire151 » Sat Aug 31, 2013 4:12 pm
Conbs,
Thanks for the input but I'm mainly looking for the dimensions of the bearings so I can order the appropriate one.
conbs
6302R Bearing
Post by conbs » Sat Aug 31, 2013 4:41 pm
Ebay 141005973772
The listing includes the dimensions. $4.11 each with free shipping.
Spitfire151
Post by Spitfire151 » Sat Aug 31, 2013 4:52 pm
You are the man! My thanks good sir.
conbs
Wheel Bearings
Post by conbs » Sun Sep 01, 2013 6:24 am
You are welcome.
malcolmgb
Post by malcolmgb » Sun Sep 01, 2013 6:01 pm
Spitfire151 wrote:Conbs,
Just to be clear, he gave you the bearing number [6302], that is a standard bearing number Worldwide and if you do a search of a reputable supplier the bearing could be bought and the dimensions would be given.
Inside Diameter: 15mm
Outside Diameter: 42mm
Width: 13mm
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
