My Dream Begins (Restoration Project)
Bradha562
Post by Bradha562 » Sun Oct 20, 2013 10:51 pm
Picked up this 65-66 CA77 a few weeks ago;
The wiring is mostly intact;
Did you notice the awesome toggle switch brakelight switch?Image
Now the bad stuff:
The slide inside the carb that holds the throttle cable is stuck (won't slide) I sprayed some carb cleaner in there, hopefully it'll loosen up.
I can't remove the oil dipstick;
Image I've sprayed PB Blaster on it, I'm hoping that loosens that up. The PO gave me an extra tank but I need to pull the petcock off the old rusty one. PB Blaster on the petcock screws;
The remaining misc. parts I have;
Image New battery and Tank repair kit.
Any suggestions would be much appreciated. Thanks
brewsky
Post by brewsky » Mon Oct 21, 2013 3:52 am
Welcome!
First thing I'd do is save an Ebay search for ca77 parts....looks like you may need several.
There is a list of vendors in the superhawk section
Members here are good to share info and help with parts when they have extras
I would try boiling that carb in a pot of water and simple green
Post pics of your progress
Rickytic
Post by Rickytic » Mon Oct 21, 2013 10:19 am
What part of So Cal are you from?
Bradha562
Post by Bradha562 » Mon Oct 21, 2013 11:15 am
Rickytic wrote:What part of So Cal are you from?
Long Beach
Jims65CA77
Post by Jims65CA77 » Mon Oct 21, 2013 11:22 am
Welcome Bradha562! I too had just bought a CA77 Dream in July and it is next in line for my restoration projects. I think I have some time before it gets too cold in the garage to work on it.
I NEVER heard of boiling water and Simple Green. I'll have to try that on my next "stuck" item.
Jim
brewsky wrote:Welcome!
Jim
Bradha562
Post by Bradha562 » Mon Oct 21, 2013 12:07 pm
Thanks for the reply Brew. Have been scouring ebay since I picked her up. I didn't post any pics but I also have the coil, air filter and tank sides with knee pads. My focus is on getting her running then hopefully being able to ride her as is and then making her look better. What else do you see that I need to get her running? The engine isn't frozen and the kicker has compression. Here is my starting list of things I know I need;
Fuel lines
Spark plugs
Points and condenser
Do you think I can salvage the solenoid?
I can't get the throttle cable out of the carb to soak it. I've seen a youtube vid of the slide being put back in but since the slide is stuck is there another way to get the cable out? I've been spraying PB Blaster on the oil dipstick and tapping at it with a wooden dowl and mallet, still no luck. Any suggestions? Thanks again.
sarals
Post by sarals » Mon Oct 21, 2013 2:05 pm
Does the solenoid work? You should be able to open it up to check the contacts.
I'd at least remove the clutch cover to have a look at the inside of the gearbox. Hopefully there is no water in there.
I can't suggest anything on the dipstick, except maybe a little heat (carefully applied).
The rims look pretty bad from the photos, you might need to replace them - unless you already have some wheels for it.
The eBaY suggestion is a good one, almost essential (it was for me). There are a surprising amount of parts on there for the Dream (and the other 72's and 77's).
Good luck with her - I look forward to following your thread!
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
