Bolt Broke When Tightening Exhaust Flange Keepers
mason123h
Post by mason123h » Sun Dec 22, 2013 10:02 am
Hello, last night while I was tightening the flange keepers on the exhaust system of m CA78, one of the bolts coming out of the block snapped off. I am almost positive that there is not enough of the bolt left to safely bolt the flange keepers on.
Is there anyway that I can fix this problem? Is there a way to disassemble to block and replace that piece?
Thanks for the help!
Re: Bolt Broke When Tightening Exhaust Flange Keepers
Post by LOUD MOUSE » Sun Dec 22, 2013 1:58 pm
What is the broken part??????????????. ...........lm
mason123h wrote:Hello, last night while I was tightening the flange keepers on the exhaust system of m CA78, one of the bolts coming out of the block snapped off. I am almost positive that there is not enough of the bolt left to safely bolt the flange keepers on.
mason123h
Post by mason123h » Sun Dec 22, 2013 2:59 pm
It is the threaded part where the flange keepers on are tightened onto by nuts. Right on the front of the block, the exhaust manifold. One of those stems where the flange keepers fit onto was broken.
Post by LOUD MOUSE » Sun Dec 22, 2013 3:08 pm
If there isn't any of the stud long enough to get vise-grip pliers on you will need to drill it out.
If you mess up the hole a helicoil works. ............lm
mason123h wrote:It is the threaded part where the flange keepers on are tightened onto by nuts. Right on the front of the block, the exhaust manifold. One of those stems where the flange keepers fit onto was broken.
cadman
Post by cadman » Sun Dec 22, 2013 6:50 pm
First - it isn't a bolt but a stud. It is in the cylinder head not the block.
Second - very unusual to break one while normally tightening - usually is broken when the nut is frozen on and you are trying to remove it. So the assumption is you were tightening too much.
Third - If you are lucky there is enough of the stud sticking out to get vise grips on it and remove it. You should soak it with something to hopefully loosen it a bit (PB Blaster or ???) then apply some heat - heat gun or propane torch. Heat the aluminum head around the bolt.
Fourth - try removal very carefully - if you break the stud off next to the cylinder head it will require drilling and trying to remove with an easy-out. This is not an easy task.
There are two different materials - aluminum cylinder head and steel stud. Very common for these two metals to seize - especially if they have been together for a long time and subject to heating and cooling cycles. Generally I always use Never-Seize on parts like these when reassembling.
If there is enough stud protruding to catch 2/3 of the nut then you can probably get by doing nothing.
malcolmgb
Post by malcolmgb » Mon Dec 23, 2013 12:19 pm
Something I have heard done is welding a nut to the broken stud using MIG the heat generated helps de-seize and you have a hex head to use a spanner/socket.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
