Ca77 305 dream rings
64dreamman
Hey yall needin a set of Standard bore piston rings for 305cc dream. I found one online but itl have to be imported:O yall got any im looking for new rings btw
Hoosier Tom
Re: Ca77 305 dream rings
Does your piston require the early issue (266) or the later which HONDA changed to the (275) thickness. ( normal CB/CL77 issue which is thinner than the (266) issue)
Question is do you know the year of issue of that piston as HONDA changed the rings and didn't show which engine number it changed at. .........lm
64dreamman wrote:Hey yall needin a set of Standard bore piston rings for 305cc dream. I found one online but itl have to be imported:O yall got any im looking for new rings btw
Early Rings
Stay away from Rings with part number C771361A.
You can also ask the seller to mic the ring vertical thickness. 1.77 for the early and 1.42 for the later rings.
Hope that helps.
Hope that helps.
64dreamman
