Just wondering what's needed to run 18" wheels from either model
Cheers
Anyone run CB or CL77 wheels on CA77
Prosuperstar
CL77 wheels are 19 inch
CB77 wheels are 18 inch
You may get fender clearance issues with the 19 inch wheels and you will have to sort out spindle diameters and spacers. CB and CL use cable rear brake actuation so you may have to rig that up for your Dream.
Front brake torque arm on the dream is different from the other two so that will need adapting at the brake anchor on the brake plate. Also you will need to check out the rotation and ratio of the speedo drive.
The CE71 Dream sport used 18 inch wheels but I'm not sure whether it had a different fender arrangement to compensate.
http://www.examiner.com/article/1959-ho ... stery-bike
Are you after the better brakes or bigger wheels? If just better brakes some CB350 parts might work better / cheaper.
Prosuperstar
