output shaft won't turn
raindriver
Post by raindriver » Mon May 05, 2014 7:17 pm
Had to do a rebuild on my '64 c78 (believe it's a JDM 305 Dream) - when I had the cases split I had all gears turning smoothly. But when I put the motor in the frame, I couldn't get the chain on because I can't turn the output shaft (with its gear for the rear-wheel chain).
I took it back out, checked that everything was good again, made sure all gears shift and shafts move as they should. Put cases back together, double-checked that output shaft was spinning freely. I left it in neutral. But as soon as I put it back in the frame, the output shaft was 'frozen' solid.
Anybody got any ideas for me on what I can do? Thx.
raindriver
Post by raindriver » Wed May 07, 2014 9:53 am
So? C'mon folks, any ideas?
Waveblaster
Post by Waveblaster » Wed May 07, 2014 10:49 am
I am no expert but the kick start locator pin may be a consideration. Threads through the gear selector side of the case. If not lined up with the slot on the kick start spindle it will press against the kickstart gear and restrict the rotation of the gearbox. If it is this you can unscrew the bolt slightly and it should free up, rotate the kickstart until it aligns with the cut-out section and tighten the bolt again.
raindriver
Post by raindriver » Wed May 07, 2014 9:25 pm
Thanks Waveblaster, I'll check that out. When apart, and before putting back in frame, when I turned the shafts the starter shaft turned also…I kinda thought that would be inconvenient while driving!
raindriver
something's missing
Post by raindriver » Thu May 15, 2014 9:56 am
Aha. Something called a 'roller, 5x6.5' that goes somewhere between the counter shaft and its end bushing is missing. The parts diagram and service manual I have didn't identify it, but the wonderful people at CMS-NL have the best fiches in the world and that helped me out.
Even a good bike doesn't work if it's missing parts!
I'll get me one 'roller, 5x6.5'.
Waveblaster
Post by Waveblaster » Thu May 15, 2014 11:17 am
note the parts list shows there are 12 required. It is a roller bearing.
5mm dia X 6.25 L.
raindriver
doh!
Post by raindriver » Thu May 15, 2014 9:10 pm
I guess it'll work better if I put these in…
Let you know how it goes.
