The 1965 CA77 is in pretty good shape and runs well with over 30K miles on it. I'm not sure if the engine has been rebuilt or not but I suspect it has. This one's going to stay together for a while until the CL is finished.
The 1967 CL77 looks pretty good from 30', but the closer you get, the more you notice that things aren't quite right. The 9K showing on the odometer might be a little off. After a little research, it looks like the fenders should be chrome (frame 1062xxx), the side cases are missing chunks, the swing arm is badly cracked, every part that has a fin has one or more broken, the chain guard is missing... and so on. On the bright side, the headlight works.
I have a few other projects in the works so these may be a little slow, but I thought I'd get started anyway.
