Battery box and air filter area
Eljeef
Post by Eljeef » Sun Jul 20, 2014 4:41 pm
Hi. I am working on assembling my Dream and I have a question for you folks. I am putting the air cleaner door on and I noticed the two wires coming off the brake light switch aren't through the grommet. Do they just get mashed between the metal air cleaner door and the frame? Also, is the door supposed to have a rubber gasket of some kind between it and the frame? Thanks.
1964-C77 305 Dream
2002 BMW R1150GS
Eljeef
Post by Eljeef » Sun Jul 20, 2014 11:12 pm
Scratch that last question about the brake stop switch wires. They must go through the grommet. I disconnected them and ran them through the grommet after shifting my wire harness around to get the slack. I am still wondering about the door to the airbox though. What holds it in place? It just falls off when I set it there. Perhaps the tool tray? Idk.
1964-C77 305 Dream
2002 BMW R1150GS
lrutt
Post by lrutt » Mon Jul 21, 2014 6:43 am
On mine, the battery holds it in place. I think I put a folded rag behind the battery just for cushioning but once the battery is secured, that plate won't go anywhere. Kind of hokey setup but it is what it is.
conbs
Air Cleaner Cover
Post by conbs » Mon Jul 21, 2014 1:43 pm
Jeff, If you look at that cover in relation to the rest of the frame there is nothing to seal where that cover fits. The air cleaner has to have plenty of air which it gets through the hollow middle of the frame. That cover blocks out the minimal (at least it should be) amount of vapor coming from the battery and that's about it.
It is a hokey setup to have the battery hold it in place but, that's what Honda came up with.
Eljeef
Post by Eljeef » Mon Jul 21, 2014 3:55 pm
Thanks Conbs. I don't want to miss anything getting this bike together after many years.
1964-C77 305 Dream
2002 BMW R1150GS
