Post
by OldStan » Thu Aug 21, 2014 10:06 pm
From what I understand seepage in that area on both sides sounds like the head skull cap casting problem with the head. I don't think the head gasket missing the fire rings is likely to cause an oil leak, more likely just a compression leak. Replacing the head won't necessarily fix the problem, the replacement could have the same problem- unless there's a way to tell before you install it that I'm not aware of.
It could be the cam covers leaking, but both sides at once is not so likely.
Just MHO, others may have more (or better) information.
63 CA78
