Combined ignition and light switch
corvette59
Post by corvette59 » Sun Sep 21, 2014 2:16 pm
I have just obtained a second hand replacement switch for my ca78
all wire colours match on both switches and so does the order of the cable connections into the 5 pin multiplug connector match on both
What is different is that the pink and yellow connection on the rear of the switch are reversed, dy is pink instead of yellow and se is yellow and not pink
these appear to be the rectifier and dynamo connections
the question is is this ok and not cause a problem
Many thanks Peter
