Throttle tube
JonnyT
Throttle tube
Post by JonnyT » Sat Oct 18, 2014 8:40 pm
The cable has gone too far inside. How do I get it out or disconnected on this 305 ?
Re: Throttle tube
Post by LOUD MOUSE » Sun Oct 19, 2014 7:53 am
Your statement is confusing.
Please explain better. .........lm
JonnyT wrote:The cable has gone too far inside. How do I get it out or disconnected on this 305 ?
JonnyT
Post by JonnyT » Sun Oct 19, 2014 7:24 pm
Thanks for even replying"......".....long day in the shop....so here goes again. I'm replacing grips on the 305 dream. I took the brake off after cutting the old grip off and turned the throttle tube, the cable end disappeared inside the tube and I can't seem to get it out again. What do I need to do? 67 ca77
rrietman
Post by rrietman » Sun Oct 19, 2014 8:08 pm
unscrew the carb top. remove with the slide. remove cable from slide. this will free up the cable and you can push it back from the carb end.
Good luck
Randy
