Another Battery Option for Early CA77s
Post by Seadog » Thu Jan 15, 2015 7:25 pm
I've been researching batteries for my new resurrection project, a 1964 CA77. I have the older style narrow battery box/shelf. I'm aware of the NOS "correct" Wisco batteries on eBay, but I'm interested in a sealed/dry option - lithium or AGM.
Lithium doesn't seem to be a contender, due to the possible overcharging of the stock system. I don't plan on adding a regulator right now.
That leaves AGM. Some here seem to like the Motorbatt MB9U, which is too wide for the earlier models. I've seen other options in threads as well. But here's another Motorbatt that might fit the bill - the model MB5U - 2.36" wide should work. I think 90 CCA would also be fine.
What say you? Opinions, please. Better AGM options, if you have them. Thanks.
http://www.motobatt.com/MB5U
MB Item Number MB5U
Voltage 12
CCA 90
Capacity (10HR) 7
Weight 2.30kg / 5.07lbs
Dimensions (in / mm) L: 4.72 (120) W: 2.36 (60) H: 5.12 (130)
Assembly Figure
Terminal Locations 4
Terminal 2, M5x2.5 (Part#MPT1)
Screws 2XMPS1 (4) M5X7
Allen Wrench 1, 3x3 (Part#MPAK1)
Terminal Caps 4, 11x5.5 (Part#2xMPC1)
Spacer None
Case Color Yellow
Cap Style NA
Replaces YB5LB, 12N53B
SRP NA
