CA77 Dream Side Cover Differences?
Post by Seadog » Fri Jan 16, 2015 7:34 pm
Do all years of the CA77 use the same sized right side covers for the coil/solenoid/rectifier compartment?
I ask because I bought a new reproduction rectifier from a great retailer, but when I installed it, the side cover hit the terminal boots and would not close. There was a ½ inch gap at the top between the cover and the frame. I did install the rectifier correctly (there's really only one way to do it). I even removed the coil and solenoid and tried again to be sure. My only other guess might be that the right side cover, which I purchased used - age unknown - might be the culprit.
Any ideas?
mike1969
side cover
Post by mike1969 » Fri Jan 16, 2015 7:49 pm
A picture would help tremendously. As far as I know they are the same size but earlier covers have a slot for the clutch cable.
Post by Seadog » Fri Jan 16, 2015 8:00 pm
Mike, I'd be happy to provide a photo of the side cover, but I've already packed the rectifier up for return, so I can't show you how it kept the cover from closing. The cover does not have a cable slot.
mike1969
side cover
Post by mike1969 » Fri Jan 16, 2015 10:12 pm
I used a RadioShack rectifier on my Dream. It's only about 2 inches square and can be attached to the original bracket. It's a 25 amp 50 volt no. 276-1185 only a few bucks and works well.
brewsky
Re: side cover
Post by brewsky » Sat Jan 17, 2015 5:59 am
mike1969 wrote:I used a RadioShack rectifier on my Dream. It's only about 2 inches square and can be attached to the original bracket. It's a 25 amp 50 volt no. 276-1185 only a few bucks and works well.
+1
Post by Seadog » Sat Jan 17, 2015 1:28 pm
Thanks Mike and Brewsky, I had wanted to stay with a new, but improved version of the old rectifier, but I'll have to go with modern technology I guess. Still wondering about possible differences in side covers though.
mike1969
side cover
Post by mike1969 » Sat Jan 17, 2015 3:23 pm
If you could post a pic of the side cover maybe we could tell you what you have. I have a side cover in good shape. If you can't post a pic I could send you pics of mine and compare. PM me.
