Battery
Backyard
Battery
Post by Backyard » Sat May 30, 2015 12:29 pm
I have a 1965 Honda Dream 305 that i am working on and have no Battery for it. Can i start it with a 12 volt Battery Charger or do i have to get a battery to see if it runs.
48lesco
Post by 48lesco » Sun May 31, 2015 8:35 am
I wouldn't use the battery charger,you can jump it from a car battery with the car NOT running.
Backyard
Post by Backyard » Tue Jun 09, 2015 11:49 am
I put the battery on and the starter chain moves but the engine does not turn over. The engine does with the kick start and i thing its the ignition dynamo rotor, starting clutch. How do i remove the ignition dynamo rotor, i have already removed the ac dynamo and the bolt in the rotor.
Post by G-Man » Tue Jun 09, 2015 12:01 pm
You screw an M16 bolt into the rotor to pull it off. They are pretty tight so the drill is to tighten the bolt and then give it a sharp tap on the end of the bolt to jar the rotor off the crank taper.
Backyard
Post by Backyard » Thu Jun 11, 2015 12:37 pm
Thanks 48 the battery works. Thank G-Man the rotor came right off with the M16-1.5 bolt.
