Is it necessary to use crush washers on all 8 studs?
Can I use 6 good steel washers, and put crush washers on the 2 outside front studs where the oil pressure is?
Cylinder head washers
Re: Cylinder head washers
1967 HONDA installed copper (ZINC PLATED) washers on the 4 corners and 4 flat steel on the middle 4. .......................lm
R100 wrote:Is it necessary to use crush washers on all 8 studs?
Excellent - I have 4 new OEM washers. I will use them on the 4 corners.LOUD MOUSE wrote:1967 HONDA installed copper (ZINC PLATED) washers on the 4 corners and 4 flat steel on the middle 4. .......................lm
Thanks LM.
Put them on the rotor and see if they stick.
I have a bin full of Look Similar and they were steel. ....................lm
R100 wrote:Excellent - I have 4 new OEM washers. I will use them on the 4 corners.LOUD MOUSE wrote:1967 HONDA installed copper (ZINC PLATED) washers on the 4 corners and 4 flat steel on the middle 4. .......................lm
Thanks LM.
They do stick. But they are the correct part number according to the fiche for my engine number (CP77E-1001821).LOUD MOUSE wrote:Put them on the rotor and see if they stick.
Thanks LM.
It specifies 90441-286-000 x 8.
Like I said I have a bin full of those. (STEEL). ..................lm
R100 wrote:They do stick. But they are the correct part number according to the fiche for my engine number (CP77E-1001821).LOUD MOUSE wrote:Put them on the rotor and see if they stick.
Thanks LM.
