ca77 neutral switch/ stator
choctaw
Post by choctaw » Tue Jan 05, 2016 3:25 pm
Can anyone please tell me how to check the neutral switch and the stator to make sure they are working? I am putting bike back together and need to make sure they are good. Thanks!
DianneB
Post by DianneB » Wed Jan 06, 2016 5:48 am
The neutral switch will show a direct connection to ground (the engine case) when in neutral and an open circuit when not in neutral.
There is a resistance reading somewhere in the service manual that you should measure between each wire - sorry but I don't have the number handy - and there should be no connection between any wire and ground.
Backyard
Neutral Switch
Post by Backyard » Sun Jul 31, 2016 10:44 am
I want to remove the Neutral Switch from my 1965, 305 Dream. If i unplug it then remove the 2 bolts, will i have to reset somthing to put it back together. Will it just go back in.
Re: Neutral Switch
Post by LOUD MOUSE » Sun Jul 31, 2016 11:36 am
Align the rod on the switch with the slot in the shift drum then install the 2 screws. (no washers). ............lm
Backyard wrote:I want to remove the Neutral Switch from my 1965, 305 Dream. If i unplug it then remove the 2 bolts, will i have to reset somthing to put it back together. Will it just go back in.
