Timing chain adjustment
Robbie63
Post by Robbie63 » Mon May 02, 2016 8:23 pm
I have put a few miles on my 305 these days and figured it's time to do the timing chain and maybe set the valves.i don't have a manual yet so any help on setting the cam chain tensioner would be appreciated.thanks rob
mike in idaho
Post by mike in idaho » Mon May 02, 2016 9:19 pm
Remove the alternator cover to expose the timing marks and roll the engine around until the pointer is on the "T" mark(top dead center). Unscrew the tappet covers and adjust whichever pair of intake/exhaust rockers are loose(on the firing stroke) to .004"or .1 mm. Roll the engine over one turn to TDC again and adjust the rockers on the opposite cylinder. With the engine still on TDC, loosen the lock nut/bolt on the cam chain adjuster on rear of the cylinder. The spring inside the adjuster will take up any slack, re-tighten the bolt and nut. You don't need to over-tighten the bolt, 5-6 foot-pounds of torque will be plenty.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
Robbie63
Post by Robbie63 » Mon May 02, 2016 10:26 pm
Thanks mike. So to get it straight anytime the engine is at open dead centre I can set the cam chain tensioner.thanks rob
Robbie63
Post by Robbie63 » Mon May 02, 2016 10:30 pm
Mike a spelling error anytime the engine is at top dead center. I can set the cam chain tensioner ,just making sure.thanks again
mike in idaho
Post by mike in idaho » Tue May 03, 2016 6:57 am
Yep, anytime it's at top dead center.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
Post by LOUD MOUSE » Tue May 03, 2016 10:48 am
This is what HONDA says to do to adjust the cam chain.
Does not agree with Top Dead Center statement. ..............lm
Per HONDA Service-Repair-Handbook, 250-305cc Twins- All Years.
Page 37, Fig. 17.
11. Replace and attach the cam chain tensioner. Refer to Figure 17 and loosen the tensioner adjustment bolt. Rotate the crankshaft until the generator rotor "T" mark is 180 degrees from the stater indicator mark and tighten the tensioner adjusting bolt. This automatically tightens the cam chain to proper tension.
mike in idaho wrote:Yep, anytime it's at top dead center.
Robbie63
Post by Robbie63 » Wed May 04, 2016 9:48 am
Ok thanks mike and loud mouse .i will make that adjustment,my benly is not real noisy but thought I'd just adjust the chain as part of a little tune up.thanks guys
