Low end miss and hesitation
Hondaboy
Post by Hondaboy » Sun Jun 05, 2016 9:33 pm
305 dream with pw22 carb it has a low end hesitation and plugs are black. I have set floats at 26.5 and have moved the needle to all positions and the best being 2nd from bottom. No miss at higher rpm. 35 low jet and 120 main jet. Carb has been ultrasonic cleaned 2 times. Could the floats still be on the rich side ? I have set the floats level to the main jet with the little jet removed. I found this information on this site. I think I need to be leaner on the float settings. Does anyone have any suggestions ? Bike will idle
G3
Carbs
Post by G3 » Sun Jun 05, 2016 11:05 pm
Have you removed the jets and wire cleaned/washed and gently blown out the small holes in them? Also- Check your tune work against LM's tuning recipe in the yellow column FAQ section here to the left.
Hondaboy
Dream 305 hesitation
Post by Hondaboy » Mon Jun 06, 2016 6:10 am
Yes I cleaned them. The carb was in very nice condition and no gas was left in it during storage. I will check the tips section. Thanks
Hondaboy
Post by Hondaboy » Thu Jun 23, 2016 11:04 pm
Has anyone experienced the running rich problem with the pw22 carb.
Hondaboy
Post by LOUD MOUSE » Fri Jun 24, 2016 7:08 am
Have you set the valves to spec and points to spec?. .................lm
Hondaboy wrote:Has anyone experienced the running rich problem with the pw22 carb.
