adjustment tappets for 65 Dream
HondaMike
Post by HondaMike » Sun Aug 07, 2016 11:29 am
Hello to all,I just purchased a 1965 CA77 Dream and i haven't got a manual yet.whats the procedure for adjusting the tappets.all advise welcome.Mike
stepper
Post by stepper » Sun Aug 07, 2016 12:39 pm
-Disconnect battery and drain and remove tank (disconnect fuel lines and unscrew 2 bolts at rear of tank making sure to not loose the rubber spacers. tank will lift up at the rear and slide off backwards at the front)
-remove tappet covers and stator cover.
-rotate the engine using the 14mm bolt on the dyno taking note of valve movement. set rotation so that the arrow on the stator is pointing at the "T" mark on the plate.
-identify valve(s) that are in the fully closed position (at highest point of movement).
-check valve stem clearance using .003", .004" and .005" feeler guages.
-loosen 10mm lock nut and adjust tappet screw to .004 clearance.
-rotate stator 360 degrees and repeat on remaining valves.
HondaMike
Tappet Adjustment
Post by HondaMike » Sun Aug 07, 2016 12:55 pm
That's just what i was looking for.Thanks so much Stepper
Nick
Post by Nick » Tue Aug 09, 2016 2:30 am
Okay, now that you got the proper way to do it, here's the guerilla way:
Remove plugs and tappet covers, bike on center stand, tranny in 3rd or 4th gear.
Put a pen, pencil or wooden chopstick down one of the plug holes and very gently nudge the rear wheel until the piston comes up to TDC. Now remove chopstick and nudge the rear wheel back and forth a few degrees in each direction and notice on which side an exhaust or intake valve moves. The side with the moving valve is at TDC on exhaust, so, with the piston repositioned at TDC, adjust the valves on the opposite side.
Rotate crank 360° and do the other side. Takes all of about 10 minutes.
Easy peasey.
After you've done it a few times you can do away with the feeler gauge too and just check clearance by feel. Problem with feeler gauges is that if the tip of valve is dished you can end up with too much clearance using a gauge.
HondaMike
Post by HondaMike » Tue Aug 09, 2016 1:02 pm
Thank you Nick that's Great advice,I look foreword to trying it out.this what i really like about this Forum everybody is so helpful.Thxs Mike
