kicked over and runs, seems to have a pretty good air leak between the carb insulators and block, (High Rev, almost sounds like shes trying to run away from time to time)
-is there a better gasket than the oring out there?
- would red rtv work between the insulator and block?
Comments, S*** or Suggestions please lol
67 cl77
-Tex-
any suggestions for gasket/ seal fix for carb insulators
Before installing heat spacers check for flatness with wet/dry paper on glass or other flat surface do the same for carb flange. After confirming that all surfaces are flat install new O-rings with grease. If you can't find the correct O-rigs, slash cut an O-ring that has the proper thickness. Don't over tighten the carb mounting nuts!
It is easy to warp the carb flange by over-tightening. After that you're on to a loser. Get the carb flanges flat and start from there.
http://www.honda305.com/forums/1961-cb7 ... 1-182.html
tex wrote:guess they weren't great I ended up cracking one of them, got a new/ used pair in decent condition going to swamp them out this week
