CB77 gauge cluster question
sfmatt79
Post by sfmatt79 » Sun Feb 19, 2017 3:10 pm
I've got a late model CB77 '69 where the gauge cluster arms both swing in the same direction.
I'd like to install a cluster from an earlier model where the arms swing in the opposite direction from each other.
Is this possible/straight forward swap?
If not, can it be done by changing a few things?
Thanks for your help for a rookie CB guy.
I have this
I want this
If I can switch I will also be shopping for the gauge cluster. Please keep your eyes peeled.
thanks again!!
email me or post here.
matthewlaw@me.com
Post by G-Man » Sun Feb 19, 2017 3:32 pm
Matt
You will need the appropriate early speedo drive for the front wheel. When you turn the wheel the cable drive rotates in the same direction as the speedo needle.
cknight
Post by cknight » Sun Feb 19, 2017 3:47 pm
You will also need a speedometer cable with the proper cable pitch (twist) for left hand rotation. The cable housings are the same. Regards, Chase
sfmatt79
Post by sfmatt79 » Sun Feb 19, 2017 3:54 pm
As I suspected.
The speedo drive on my bike now is on the right bottom side.
What does the part I need look like? Is it a different drive altogether...switch to the left side perhaps?
If you can locate a picture of what I need and or a part number that would help me.
Cheers!!
Post by G-Man » Sun Feb 19, 2017 4:27 pm
Matt - it looks exactly the same and fits in the same place. Only the internal gearing is different. You need to check with the seller which way the cable connection rotates.
sfmatt79
Post by sfmatt79 » Sun Feb 19, 2017 4:50 pm
Perfect! That's what I was expecting and hoping for.
Thanks for your help!
Cheers
