Sticky Shifter
Sticky Shifter
Freshly registered and insured, I took my Dream out on the road for the first time this afternoon. She ran fine, but I was unable to shift above 2nd. I turned back before even leaving my street. Later, I was thinking that perhaps the back of the shift lever was hitting the foot peg, but when I tried shifting the non-running bike, I found that it was not the case. Not running, I can shift into all 4 gears, but the shift feels as if it's dragging and the pedal will not reset. I shift up, but then have to tap the shift lever back down to reset. I'll check the clutch adjustment tomorrow, but in the mean time, any other ideas?
Thanks, Billiam, I adjusted the clutch cable today, using LM's procedure. New cable, well lubed, routed correctly. The clutch is a new Cush from LM. Adjusted with both adjusters in all the way, adjuster turned right to stop, then left to stop, then back to the right, then back left 1/8 inch and locked it down. I used both cable adjusters to get about about 1/4 of free play at the lever. The clutch seems to work easily and smoothly, but the gear change petal still drags and won't reset. I fear that I didn't get the transmission back together correctly. Shift drum? I dunno.
Billiam wrote:Sounds like clutch drag Seadog. Mine would not select neutral with the engine running.
Engine off - sweet. New cable and and kept adjusting. Now acceptable - just. Best of Luck.
Can you call me?. ...............lm
Seadog wrote:Thanks, Billiam, I adjusted the clutch cable today, using LM's procedure. New cable, well lubed, routed correctly. The clutch is a new Cush from LM. Adjusted with both adjusters in all the way, adjuster turned right to stop, then left to stop, then back to the right, then back left 1/8 inch and locked it down. I used both cable adjusters to get about about 1/4 of free play at the lever. The clutch seems to work easily and smoothly, but the gear change petal still drags and won't reset. I fear that I didn't get the transmission back together correctly. Shift drum? I dunno.
Tomorrow is OK.
It may help. .................lm
Seadog wrote:Yes, with gratitude, but if it's okay with you, would tomorrow be good? I have too many irons in the fire today and promises to keep. Should I have the clutch side cover off before I call?
"Jesus bolt"?
LOUD MOUSE wrote:Can you call me?. ...............lm
