CR29/31 capellini manifolds
oceancargo
Post by oceancargo » Tue May 30, 2017 1:31 pm
Good day-
Went through the pages looking for this topic that must surely have been discussed by now?
I have a CL77 big bore, big cam, big oil pump daily rider. Want to look into a little more flow and volume. Saw the capellini manifolds on eBay and figured somebody must've taken the bait.
Sudco mostly only sells these carbs in pairs (or fours) mounted on a bracket with a single cable actuator to run both carbs. Considerable expense to split the pull back to double to use stock Honda throttle cable. Has anyone found a good single pull solution?
Anyone managed to mount these carbs in their stock frame CL77?
Total overkill and not enough flow velocity at low RPM to make these a viable option?
Other advice or knowledge welcome!
Cheers,
Trey
cron
