Best way to lock engine to remove dynamo rotor bolt?
GregMcN
Post by GregMcN » Sat Aug 12, 2017 1:27 pm
As the title, I need to remove dynamo rotor so was wondering what the recommended method was to lock the engine to undo the dynamo rotor bolt?
Thanks Greg
Post by G-Man » Sat Aug 12, 2017 1:45 pm
Greg
Just whack the spanner and the inertia of the crank will be enough.
cknight
Post by cknight » Sun Aug 13, 2017 9:37 am
Also, if the stator is removed, you can use a strap wrench to hold the rotor, then loosen the bolt. Regards, Chase
GregMcN
Post by GregMcN » Sun Aug 13, 2017 2:46 pm
Thanks G and CK.
Snapped the last strap wrench I had , must get a replacement.
Whacking it worked fine.
