1965 305 CL77 gas
JAWDOC
1965 305 CL77 gas
Post by JAWDOC » Sat Sep 09, 2017 1:48 pm
Is there any advantage to using non ethanol gas in my 305 CL also. When I try to start from cold it can take 6-8 kicks any suggestions, Thanks
Re: 1965 305 CL77 gas
Post by G-Man » Sat Sep 09, 2017 2:39 pm
We don't have much ethanol in fuel in teh UK so I cannot answer that.
As for starting, you just need to go through all the things that can affect it.
Are the carbs clean?
Is the float level correct?
Are you using the choke correctly? (Up for choke on. Down to run once warmed up)
Is the ignition timing and valve timing right?
Good plugs?
Good Compression?
Etc.
JAWDOC wrote:Is there any advantage to using non ethanol gas in my 305 CL also. When I try to start from cold it can take 6-8 kicks any suggestions, Thanks
