Throttle Cable Fabrication
stonelyon49
Post by stonelyon49 » Tue Sep 12, 2017 11:05 am
I want to install longer handlebars on my CA77 (so I can ride in a more upright position) than stock but am having trouble finding a shop, preferably local in Akron/Canton Ohio, to fabricate a throttle cable. Any leads would be appreciated.
rrietman
Post by rrietman » Tue Sep 12, 2017 10:15 pm
early? late? totally different cables. there are , out there, ready made longer cables for each setup.cruz ebay and learn. what do you have on it now? stock bars/cables put you pretty straight up on the dreams.
Good luck
Randy
stonelyon49
Post by stonelyon49 » Tue Oct 17, 2017 11:01 am
Just following up on this post. I called around to various local shops but came up empty and, after not receiving anything useful here, I decided to make my own. I bought an inexpensive solder pot and used an old cable and fittings that I had lying around from previous projects. It takes a little skill but a lot of patience to do it right.
Post by G-Man » Tue Oct 17, 2017 11:20 am
Excellent!
You got a new cable and some education.
So much better to do your own thing and then you get exactly what you need.
stonelyon49 wrote:Just following up on this post. I called around to various local shops but came up empty and, after not receiving anything useful here, I decided to make my own. I bought an inexpensive solder pot and used an old cable and fittings that I had lying around from previous projects. It takes a little skill but a lot of patience to do it right.
Geoff Hastings
Post by Geoff Hastings » Tue Oct 17, 2017 11:22 am
Making your own cables is very easy, just make sure that if you buy stainless steel inner cable that you use stainless solder.
