Rims
thepunisher2007
Rims
Post by thepunisher2007 » Fri Oct 13, 2017 2:27 pm
Hi All
I need to replace the front rim on my early CL77 due to flat spot but finding good ones is becoming more tricky over here in the UK (IE there seam to be none). Is there any reason why I cant use the rim of an early rear? is there really enough of a difference to make it an issue as long as the Tyre fits and i use the original front spokes?as there both 19inch i cant see the problem
Also is there any reason a later model rim front or rear wouldn't fit?
its only the rim i need I have tons of spare spokes and the hub is good
any advice apricates
Cheer Mike
Post by G-Man » Sat Oct 14, 2017 12:42 pm
Hi Mike
I may have a spare, re-chromed one. I'll let you know, but I think my spares are CL72 whuch will have the wrong spoke angles.
thepunisher2007
Post by thepunisher2007 » Sat Oct 14, 2017 1:42 pm
thanks. it's and early 77 1965 so 72 would be right. i took the wheels i'm using at the min off cl72 i thought they where in perfect condition until i noticed the flare spot.
is it safe to assume the later model rims won't fit as per your mention of spoke angles?
Post by G-Man » Sat Oct 14, 2017 2:44 pm
OK - I definitely have a small brake rim going spare. Was going to get it re-chromed but you could have it as-is if you wish......
Will get some pics for you.
thepunisher2007 wrote:thanks. it's and early 77 1965 so 72 would be right. i took the wheels i'm using at the min off cl72 i thought they where in perfect condition until i noticed the flare spot.
thepunisher2007
Post by thepunisher2007 » Sat Oct 14, 2017 3:00 pm
that sounds great thanks
Post by G-Man » Sat Oct 14, 2017 4:08 pm
PM me your email address and I'll send some pics tomorrow.
thepunisher2007 wrote:that sounds great thanks
thepunisher2007
Post by thepunisher2007 » Sat Oct 14, 2017 4:35 pm
Pm'd thank you
