My CP77 is difficult to start and then I realized that the left cylinder wasn't firing. If I pulled the spark cap off the about 1/4" it would start to fire. Few minutes later I would press the cap on fully and it was fine.
Anybody have any ideas ?
Left Cylinder Has Intermittent Spark
Cap'n Dave
Re: Left Cylinder Has Intermittent Spark
Plugs clean and fresh?
Carbs jetted correctly?
Ignition timing set properly?
Try swapping ignition parts (plugs / caps ) left tyo right.
By pulling the lead away from the plug you have essentially incresed the voltage at the plug points.
Cap'n Dave wrote:My CP77 is difficult to start and then I realized that the left cylinder wasn't firing. If I pulled the spark cap off the about 1/4" it would start to fire. Few minutes later I would press the cap on fully and it was fine.
