PETCOCK
PETCOCK
HELLO. OK NEW TO THE SIGHT THANX FOR HAVIN ME. OK I PICKED UP A 67 SCRAMLER. IT WAS SOMEONE ELSES PROJECT SO IT IS IN PIECES. MY QUESTION IS THE PETCOCK THAT CAME WITH IT WAS TRASHED IT WAS A DUAL FEED. EACH CARB CONECTS TO IT. THE EXTRA ONE THAT CAME WITH IT HAS DUAL FEED BUT ALSO HAS A THIRD FEED ON IT. WHERE DOES THIS CONECT TO? THE GAS TANK DOES NOT HAVE A CROSS OVER FITTING ON IT . ANY HELP WOULD BE GREATLY APPRECIATED.
petcock
from what i understand the later ones didnt have the cross over pipe, or you have an even later model tank . you can get hold of the proper petcock on Ebay easily...hang onto that triple pipe petcock as its made from unobtainium and worth some $$$$
Re: PETCOCK
Mago is correct.
You have a 67 issue tank and fuel valve.
No 3rd outlet on the valve and no tap on the tank.
You can use the valve by bending a piece of tubing over and holding it closed with wire or Zip tie. .......................lm
fatboy98 wrote:HELLO. OK NEW TO THE SIGHT THANX FOR HAVIN ME. OK I PICKED UP A 67 SCRAMLER. IT WAS SOMEONE ELSES PROJECT SO IT IS IN PIECES. MY QUESTION IS THE PETCOCK THAT CAME WITH IT WAS TRASHED IT WAS A DUAL FEED. EACH CARB CONECTS TO IT. THE EXTRA ONE THAT CAME WITH IT HAS DUAL FEED BUT ALSO HAS A THIRD FEED ON IT. WHERE DOES THIS CONECT TO? THE GAS TANK DOES NOT HAVE A CROSS OVER FITTING ON IT . ANY HELP WOULD BE GREATLY APPRECIATED.
Re: PETCOCK
LOUD MOUSE wrote:Mago is correct.
OK SO IF I PLUG OFF THAT 3rd FEED I CAN USE THAT PETCOCK? THE BIKE ALSO CAME WITH 2 TANKS THEY ARE ALLMOST IDENTICAL EXCEPT FOR ONE HAS A CROSS OVER TUBE ON THE BOTTOM AND ONE DOES NOT. ONE HAS A SEEM DOWN THE MIDDLE AND ONE DOES NOT. I WAS TOLD BY PREVIOUS OWNER THAT THE ONE WITH NO CROSS OVER WAS THE ORIGINAL ONE TO THE BIKE.THANX FOR THE HELP.
The 67 issue does have the seam and no cross over. ..............lm
fatboy98 wrote:OK SO IF I PLUG OFF THAT 3rd FEED I CAN USE THAT PETCOCK? THE BIKE ALSO CAME WITH 2 TANKS THEY ARE ALLMOST IDENTICAL EXCEPT FOR ONE HAS A CROSS OVER TUBE ON THE BOTTOM AND ONE DOES NOT. ONE HAS A SEEM DOWN THE MIDDLE AND ONE DOES NOT. I WAS TOLD BY PREVIOUS OWNER THAT THE ONE WITH NO CROSS OVER WAS THE ORIGINAL ONE TO THE BIKE.THANX FOR THE HELP.
